some torque settings on my 520 EXC
I'm doing a motard conversion on my 2002 520 EXC, and will be putting a spare rotor on the front and back, as well as an extra sprocket on the rear wheel, so the swap back to dirt will be easier.
Anyone have a shop manual with the torque settings for the rotor and sprocket bolts?
later, docgonzo
Brake disc 11 ftlb
Sprocket 26 ft lb
Use Red Loctite on both sets of bolts.
I have some torque spec sheets from the owners manual at the 2nd link under my email address in this post that should help.
But on rotor and sprocket bolts, I don't use them. I get the nuts, bolts, threads clean and use loctite (blue on the rotor bolts, red on the sprockets) and get them as tight as I can.
Thanks, fellows. I have an owner's manual, and found the page with all the torque settings. Pretty decent manual!
later, docgonzo
