Back spring or front spring first
Hey guys. what do you guys think i should do in spring wise?im thinking about going with the bbr springs but i don't now if i should get the back spring or front first.It feels as if i bottom out my front suspension more as then the back.the back feels a bit soft tho...i have a firend that just rasied his stock suspension a bit and mad it stiffer.should i do that and buy the front springs?Any help would help
thanks in advance
"Back easier to replace"
Are you joking??
The back spring is sooooo much harder to replace than the front, all you do is take off the fork caps on the top and pull the springs out, takes 5 minutes at the max. The back took longer because you had to undo the linkage and take it out.
