joker springs: frist ride impression
i weight 150 w/ gear.
ride trials agresivly. jump less that 5' high.
i hade some old yamaha spring that fit in my forks b/f the
joker springs. they were better than stock but still bottomed bad. the back was stock.
i put the joker fork springs on first.
i have no 15 W oil so i used ATF. looked about like 15-20w
my left leg was leaking a bit so i poped out the dust seal to have a look. couldn't get the main out to clean or replace so i cleaned what i could and put the springs in. put the legs back on and went for a ride. Big help but could be a little stiffer.
so then i put the rear on with 3/4'' preload. it said it was a 425lb. it looked way bigger wire dia and tighter coils.
O, i also mesured betwean each coil and then X the wind.
fork springs was 63 x 3/32 rear was 6 x 1/2 i was making sure i wasn't getting any coil binding to limit my travel.
that was 3'' on teh back the rear shock is a 2'' stroke and
the fork was like 6.3 ish not close to the advertized 7''
but that is not including the bottom out bumper.
now i rode with both new strings in and didn't like it much.
i think the rear is to stiff. i am sitting back more to push intot he susspention to much. it just dosn't feel matched. i stand all the time so mabey if i was sitting more it would be better? lol 😢
anywy my ?tion is anyone know what a bbr or stack spring rate is so i know hwere to go from my 425 joker?
thanks alex
I can't really answer your ? Sorry.
But just to comment I have Joker springs on my TTR. I haven't trail ridden it yet, but for mini mototard they work great compared to stock. I can take corners faster now before the chatter starts. I weigh 200lbs with gear. Wheelies and stoppies are alot easier also with the new springs.
