Removing grips for new handlebars???
How do I re-move, save and re-use my old grips and throttle bodies for my new renthal handle bars???? Thanks.
Easy. Just take some rubbing alcohol and a scredriver. Wet the screwdriver and stick it betweek the bar/throttle and the grip. Do this in severyal sport around the grip and it'll slide right off. Then the rubbing alcohol will dry, leaving the grip unharmed.
Cool, I'll ty it a lil later,
Thanks
You can also use your air compressor and blow it off, that's what I did.
If you spray WD 40, the oil will stay in the rubber, and you will not be able to reuse them
Use rubbing alcohol because the alcohol dries off.
And the air compresser would work if there was no grip glue. I use that metod when there's no grip glue 😢
and for putting them on new handlebars, you could just put them on and add wire around the grips, dont need glue.
Got mad, one thing lead to another and before I knew it I cut the damn things off and was at the store buying new grips. hahahahahah 😢
