matt_rohr Posted December 3, 2004 my brother has an 02wr250f which started running like hell all at once. We've done everyhing. different carbs ignitions checked cam timing ,flywheel position and finally a new coil from an 04 you name it. It still wont kick start and when it does fire wont run at all below about 3000rpm or so. It does improve quit a bit when the tps is disconnected. A knowledgable friend suggested it was probably the wiring harness. We've decided to order and try one. My queston is will an 04 hook up to an 02 motor -stator, keeping in mind he has an 04 coil now or should he get an 02 and make a lead to fit the o4 coil as it is now. Appreciate any help, we have an important race sunday. Matt Share this post Link to post Share on other sites
dkwkid Posted December 3, 2004 Check the position of your stator on the crank. You may have sheared the woodruff key for the stator causing all kinds of trouble. also, replace the spark plug even though it looks o.k. A bad plug that looked o.k. cost me a race once. Share this post Link to post Share on other sites
paul4 Posted December 6, 2004 Did the problem start while he was riding?, or when he went to start it up to ride? If it happened while he was riding, fell or stalled it out on a bump, the woodruff key is it. Happened to me last year, e-start would not work, and kicking would not do it either. When it would start, it ran like sxxt. Shop cost me $135, recall on WR450's, but not on the 250's. Share this post Link to post Share on other sites
matt_rohr Posted December 8, 2004 Thanks for your imput you guys. I've checked the flywheel and put two new plugs in it. It is some what intermitant 95% bearly runs we may just try a harness. I'll let you know what we find out. I'm just not sure if the o4 harness will fit an 02 with an 04 coil or not? Anyone? Matt Share this post Link to post Share on other sites
WRookie My Rides (2) Posted December 8, 2004 "different carbs ignitions" I'm not sure what you mean by that. You changed carbs and ignitions? You say it runs above 3000 rpm. To me it sounds like the pilot jet or pilot air jet is clogged. Another WAG is the floats could be set too high and the starter circuit could be sucking extra fuel. I don't understand how a bad wiring harness could affect the motor only below a set rpm. Let us know when you get it working again. Good luck. Share this post Link to post Share on other sites
Rick_Kienle Posted December 9, 2004 In response to your original question, the 04 harness will not work on the 02 model. The 01, 02 and 03 models all had different wiring harnesses. I believe the 03, 04, and 05 are the same but I am not 100% sure. Share this post Link to post Share on other sites
