joeizdaman Posted December 3, 2004 I'm set to fix the leaky waterpump b4 it happens but i just discovered that i need to get the whole engine case cover out and not just the water pump cover. The million dolar question is... that means i have to drain the engine oil right? That also means i have to put 1.7 litres of new engine oil back after the fix right? Does anyone has a real pic of where the RTV is applied to cos from the web it looks really general. I get all confused from searching the previous posts... And what's the amount of RTV to use... whole gunk of RTV, a bead etc... can someone help me and be a lil bit more specific 😢 Thanks guys. 😢 Share this post Link to post Share on other sites
OLDFATGUYRACING Posted December 3, 2004 You can lean or lay the bike over on its side, that is what I did. The rtv is applied to the small void under the seal. I am sure someone will post a link to the photo, just be patient. good luck 😢 Share this post Link to post Share on other sites
joeizdaman Posted December 3, 2004 wow u layed the bike on its side.. maybe i should try... i hwte to change the oil cos i just changed them an only went dualsporting for maybe less than 200miles Share this post Link to post Share on other sites
Wayward Son Posted December 3, 2004 you put the rtv here..... http://groups.msn.com/burnedsdrzpage/waterpumppics.msnw?action=ShowPhoto&PhotoID=1787 Share this post Link to post Share on other sites
joeizdaman Posted December 3, 2004 thanks burned.. just what i need that really clear things up... 😢 Share this post Link to post Share on other sites
OLDFATGUYRACING Posted December 3, 2004 That was the photo I was talking about 😢 . Make sure you fill the void, and get the ceramic-rubber seal pressed all the way in. When I first did it, mine was not quite in all the way. Then I could not get it back together correctly. Thanks Burned for posting that photo again. 😢 Share this post Link to post Share on other sites
