red64chevelle   Posted December 3, 2004 😢 Hello everybody. I wanted to know what I should do to help out my top end performance. I have an 04 CRF230, with the Honda full power needle, 132 jet, Snorkle removed, Uni-filter and Pro-Circuit T4 exhaust. My problem is that I have a great bottom end, but when I am at the upper end, the motor really looses power. I am getting alot of discoloration on my header as well. I was thinking that I might have to increase the jet size, but wanted to see what others thought first. Thanks in advance. Share this post Link to post Share on other sites
Toast   Posted December 4, 2004 Pipes discolor, that's not a problem. Does it backfire at all on let off? For $4 each I'd probably just buy a spread of main jets. Jump to the 138 first & see if that makes a change for the better. If the pipe flows better than the stock exhaust you should be lean & require a bigger main jet. You might want to do some wide open throttle runs up hill. Before you let off the throttle pull in the clutch & hit the kill switch then come to stop & check the spark plug. Helps to have a new plug for this. Shooting for a tan color. Welcome to TT 😢 Share this post Link to post Share on other sites
