Jumping the DRZ125
Yes the bike will because of the engine acting as part of the frame. so when you jump you put stress on the engine crank case. And will crack if you do nothing about it. I was jumping about 5 feet high on my KLX/DRZ125 then when i was looking at my bike i noticed a leak of oil and sure enogh it was a cracked crankcase. But BBRMOTORSPORTS makes a engine cradle which connects the one end of the frame to the other end. It will run you like $140. The cradle takes the stress from your engine caused by jumping. Also BBR sells stiffer fork springs and rear shock spings.
