04wr250f Posted December 3, 2004 I looked on Yamaha of Troy website for different part #'s but they do not list the oem #'s.Where can I find oem part #'s to do some cross referencing? Currently looking to see if yz radiators would cross over to a wr and still retain the wr plastic. Let me know! Thanks!!!! Mark Share this post Link to post Share on other sites
toddMH Posted December 3, 2004 http://parts.yamaha-motor.com/ try there Share this post Link to post Share on other sites
grayracer513 My Ride Posted December 3, 2004 Yamaha's Online Parts Catalogs: http://parts.yamaha-motor.com/ 😢 Share this post Link to post Share on other sites
04wr250f Posted December 3, 2004 Drats!!! Wouldn't you know it, the rad. on a yz are different part #'s!!! Thanks guys!!!! Mark Share this post Link to post Share on other sites
SUnruh My Rides (2) Posted December 3, 2004 that couldn't be because one is left and one right? or has a filler neck Share this post Link to post Share on other sites
Highpockets Posted December 3, 2004 I had this same issue a couple of months ago. The numbers when cross referenced didn't match so I played it safe and ordered a WR radiator from local dealer. I have since found out that when you change gas tanks on the WR you have to use the YZF shrouds. Also IMS sells replacement radiators that fit WR or YZF. I believe the radiators are the same despite different part numbers. Hope it helps. 😢 Share this post Link to post Share on other sites
SUnruh My Rides (2) Posted December 3, 2004 the WR has a wider radiator. it has 1 more row of cooling fins and a another tube. not the same. Share this post Link to post Share on other sites
bullet3z Posted December 4, 2004 What a great link for part numbers, thanks. 😢😢😢 Share this post Link to post Share on other sites
wrooster Posted December 4, 2004 I have since found out that when you change gas tanks on the WR you have to use the YZF shrouds. WRF shrouds will fit on a YZF-tank equipped WRF; they bend outward a minscule amount, that's all. jim aka the wrooster '01 wr250f Share this post Link to post Share on other sites
250Thumpher Posted December 5, 2004 The TT faq has the 03 YZF manual. I use it for my 01 once in a while... Share this post Link to post Share on other sites
04wr250f Posted December 7, 2004 What was the name of the place that was mentioned here that rebuilds/repairs these radiators? Thanks!!! Mark Share this post Link to post Share on other sites
04wr250f Posted December 8, 2004 http://www.motorcycleradiators.com/ This is the one!!! Thanks Barton!!!!! Mark Share this post Link to post Share on other sites
Rick_Kienle Posted December 9, 2004 WRF shrouds will fit on a YZF-tank equipped WRF; On the 01-02 models both the tank and the radiators were wider so the shrouds were identicle. This would cause the slight fitment problem that wrooster described but they would still work. On the 03+ models, only the WR radiatiors are wider as the tank shape has been redesigned. As such, the YZ and WR actually use different shrouds. However, unless you are changing your radiators the shrouds should work and should fit just fine. Share this post Link to post Share on other sites
