tjjordan Posted December 3, 2004 I am considering purchasing a 525 EXC. I ride year around and live in snow country, and have a kit to convert the bike to a snow bike. My question is can the stock EXC or MXC lighting/stator support heated grips. The spec's I have seen indicate heated grips range from 18 watts on low to up to 56 watts on high on some kits, using approx. 3 amps. Has anyone tried or does anyone have output spec's available on the big EXC? I have checked out the other post and some good information found, just would like numbers if possible. Thanks Sno X Cycle Conversion Kits Share this post Link to post Share on other sites
Burnrider Posted December 3, 2004 Dual Star Grip heaters run 36 watts on high. They are excellent. Try Dualstar.com It's a dealer direct item in Washington State. Share this post Link to post Share on other sites
tjjordan Posted December 3, 2004 I tried www.Dualstar.com and a engineering sight from NY came up. Did I type it in correctly? Share this post Link to post Share on other sites
Burnrider Posted December 3, 2004 http://www.dual-star.com/ This one worked Share this post Link to post Share on other sites
jeb Posted December 5, 2004 With the dual star's, you only need a thin wrap of electrical tape on the clutch side. Share this post Link to post Share on other sites
pcm Posted December 16, 2004 Never used or installed heated grips. How does this system work on the throttle side? I'm assuming the element needs to be between the plastic twist piece of throttle and the handle bar. Is this the case? And does the throttle work OK & does this wear out the element? And most of all does it do the job?? Share this post Link to post Share on other sites
DDNMC78X Posted December 16, 2004 I have the stick on pads from Moose on my 200 EXC, you then can use whatever grips you like. With no resistor i have to run the grips on low and my headlight on to keep from getting to hot. I ride without gloves so i need the heaters. Share this post Link to post Share on other sites
jeb Posted December 16, 2004 Never used or installed heated grips. How does this system work on the throttle side? I'm assuming the element needs to be between the plastic twist piece of throttle and the handle bar. Is this the case? And does the throttle work OK & does this wear out the element? And most of all does it do the job?? No, the element goes on top of the throttle tube, right under the grip. The dual-stars are pretty easy to install. Share this post Link to post Share on other sites
pcm Posted December 17, 2004 No, the element goes on top of the throttle tube, right under the grip. The dual-stars are pretty easy to install. Thanks John, please excuse me for wondering; but how in the heck does the wiring get routed if the element is twisting all the time? This is probably one of those very obvious things I'm not getting. Will they work with the Acerbis shielded alum bark buster style guards? Share this post Link to post Share on other sites
Chas_M Posted December 18, 2004 The Dual Star grips are easy to install. Even though they are dedicated to clutch and throttle side, as "jeb" pointed out, with aluminum bars you still need to insulate the clutch side with several wraps of electrical or duct tape. No problem with wire twisting on the throttle side after a small loop of wiring is zip tied to allow free movement of throttle and wires. I prefer to wire the hot grips into the hot lead to the headlight because the grips will automatically shut off when the engine is turned off, plus wiring the grips this way doesn't put an excessive load on the battery. Share this post Link to post Share on other sites
jeb Posted December 18, 2004 Chas is correct on the throttle side routing. Just make a loop and ziptie it. I have mine on the bike all year and they hold up great. With the Dual-Star's, you'll only need one wrap of elect tape under the clutch side grip. Share this post Link to post Share on other sites
pcm Posted December 19, 2004 Thanks Chas & John, I got it. The obvious it is. It seems pretty flimsy to have the wire twist like that, but I can see zip tie with the loop would do the trick. Thanks again & have a great holiday. Share this post Link to post Share on other sites
