Drz 400s Bars Are Too Close
I recently switched over to CR-HI FATBARS using the Pro taper adaptors and the height is now perfect but the bars are too close to me when standing. Feels like they need to be about an inch or two more forward. Any suggestions?
Aftermarket triple clamp with adjustable mounts. That way you can ditch the adapters, and get the height and front/back setting as you would like. Though,, you'll not get an increase forward movement measured in inches 😢
Why not roll the bars forward in the mount? placing the bar end farther forward?
Thanks, I did roll the bars as far forward as was still comfortable. The only problem I saw with an aftermarket upper triple clamp was that they only seemed to move the mounts 10 mm forward and it feels like I need more than that. Also at that point the bars will hit the computer which then needs to be pushed forward.
Where can I find more info on the Big Dr risers? Is there a web page or something where I can see them? Thanks.
