fmx3313   Posted December 6, 2004 does any one have any tips or know how to straighten the subframe 😢 Share this post Link to post Share on other sites
ThumperKid250F Â Â Posted December 6, 2004 i bent mine and my dad took some wood and vice grips and bar clamps.. than heated it a little JUST a little.. and he just turned the bar camps and it started to to form back.. Share this post Link to post Share on other sites
holeshotmaster17 Â Â Posted December 6, 2004 If you have a crowbar or a long metal bar you can straighten it out. Share this post Link to post Share on other sites
fmx3313 Â Â Posted December 6, 2004 do u heat i when using a crowbar, and do u have to get it perfectly straight (would a level work?) Share this post Link to post Share on other sites
holeshotmaster17 Â Â Posted December 6, 2004 How bad is it bent? Share this post Link to post Share on other sites
fmx3313 Â Â Posted December 6, 2004 just a little the left side needs to come up a little bit Share this post Link to post Share on other sites
tiny30 Â Â Posted December 6, 2004 If you heat it use a propane torch, nothing hotter than that. Share this post Link to post Share on other sites
250Thumpher   Posted December 6, 2004 Yeah, if you need to get it red hot to bend it, say goodby to it. Share this post Link to post Share on other sites
mtrdrms   Posted December 6, 2004 I used a long piece of pipe and just tweaked it a little at a time and then stood back and looked at it. it straighted out fine. Share this post Link to post Share on other sites
grayracer513   My Ride Posted December 6, 2004 Yeah, if you need to get it red hot to bend it, say goodby to it. The problem is that aluminum doesn't get red. Using a torch to heat it, it will sort of develop a "skin" on the outside, and seem to melt inside of that. Your first clue will be when it falls on the floor in a puddle. If you use heat, do so very carefully. You need to have bending pressure on the part so that you can tell when it softens, but you have to strike a balance between the heat and pressure. Too much pressure too cold can crack the tubing. Too much heat and it's gone. Try to do what you can without heat and see how it responds. Use pieces of wood to prevent denting the tubing. There's a lot of "feel" and judgment involved in something like this, and unfortunately, that can only come with experience. If you doubt your ability at any point, don't be afraid to ask a pro. Good Luck 😢 Share this post Link to post Share on other sites
cuevas9c   Posted December 8, 2004 if you cant straigthen in check Off Road Plus for a new AC RACING subframe. i got mine for 149.00 plus shipping it worked great Share this post Link to post Share on other sites
fmx3313 Â Â Posted December 8, 2004 if i cant straighten it my uncle was telling me of a titamium subframe he got for $150 online, anyone have one? Share this post Link to post Share on other sites
GaSs   Posted December 8, 2004 How hard do u have to fall to bend your frame cause i fell off a cliff and my sub frame didnt bend?? Or was i just lucky 😢 Share this post Link to post Share on other sites
ilikemud   Posted December 8, 2004 its not how hard its usualy how casing a doubble and landing on the subframe would do it Share this post Link to post Share on other sites
