Gato_Volador Posted December 6, 2004 WHen the outside of the plug is rich black and the inner core and tip is ashy white, what is the plug trying to tell me? I am running a 2002 Honda CRF450 with the following: FMF Factory 4 Exhaust JD Needle Red (4th clip position) 42 Slow Jet 178 Main Jet PowerNow Valve Fuel Screw 7/8 turn out KBB Valve Set and in spec. TwinAir Carbon protected Filter lightly oiled 500' Above Sea Level, 90 degrees, humid, MX Thanks, Phil. Share this post Link to post Share on other sites
yamaha259 Posted December 6, 2004 I would say lean, but ask around some more. A good brown colour is what you want. Share this post Link to post Share on other sites
Wayward Son Posted December 6, 2004 i tells you that reading spark plugs doesnt do any good with modern fuels. Share this post Link to post Share on other sites
Silver Surfer Posted December 7, 2004 this spark plug atlas has every state of plug... 😢http://www.dansmc.com/spark_plugs/spark_plugs_catalog.html i tells you that reading spark plugs doesnt do any good with modern fuels.burned, can you please elaborate on this??? Share this post Link to post Share on other sites
Wayward Son Posted December 7, 2004 additives in modern fuels give false plug colors.the plugs in my bikes always look "lean". but they make max power on the dyno and the CO and A/F readings are perfect. you will do nothing but chase your tail trying jet by plug color. the only thing i look for on the plug any more is signs of detonation. Share this post Link to post Share on other sites
Wayward Son Posted December 7, 2004 notice the info on that page is on a phamplet from 1977. Share this post Link to post Share on other sites
Gato_Volador Posted December 7, 2004 Forgot to mention I am using regular High Octane 92 pump gas. Thanks for the responses Share this post Link to post Share on other sites
James_Dean Posted December 7, 2004 You should be looking at the inner core, but as burned said, the reading is difficult to evaluate and be conclusive. You can ride with different settings to get a "feel" for richer and leaner jetting or have a shop set the mixture with a CO meter. In general, the jetting you posted is close to what others use in your conditions (try a #175 MJ). The humidity and temp will favor leaner settings and a #40 pilot jet could be used to get the fuel screw closer to 1 1/2 turns out. Thanks, James Share this post Link to post Share on other sites
