BK14MX Posted December 6, 2004 Went to a track this weekend with some pretty big jumps, not just long, but flippin high too. I was having trouble when I landed from the biggest one, my bike was bogging/hesitating almost everytime I hit the ground. Its a big jump with ALOT of air time, I havent had a chance to take the carb apart yet, but Im guessing all things being clean in it, that maybe the float level is too low??? Anyone else ever run into this?? 😢 Share this post Link to post Share on other sites
Yamaha_85 Posted December 6, 2004 You need this: CARBY VENT SYSTEM (SINGLE CARB) When your motor sputters through the whoops or bogs when landing from a jump and G-outs, it is often caused by fuel being vapor-locked in the standard downward carburetor vent tubes. This vapor-lock action is similar to putting your Finger over a drinking straw to keep the Liquid trapped inside. By venting both hoses upward, the PC system allows fuel to drain through the downward vent tubes without hesitation and ensures continues air flow into the carburetor. To be sure that the upward tubes don't draw or get clogged with dirt, the foam filter-equipped vent box filters the air that the system breathes. Another vital function of the vent box is keeping water out of the upward vent tubes when you wash your vehicle. With the PC system, off-road riders don't experience the bogging common in stream crossings when the drain tubes are submerged in water and while being bounced around on rough terrain. Although the standard venting is improved on some of the newer motocrossers, 'bogging' problems still persist over obstacles which result in continuous bouncing, such as whoops. The new PC system includes additional T-vents to improve venting on these motor*cycles, and results in fewer vent lines hanging from the bottom of the motorcycle. PS. Are you landing hard on the gas? Share this post Link to post Share on other sites
BK14MX Posted December 6, 2004 yeah, Im on the gas hard on the landing. Ive heard of those vent systems, but never knew of anyone using them. Thanks for the information. Share this post Link to post Share on other sites
