Weeeeee Posted December 7, 2004 I have a Garmin Etrex, with the cigarette lighter adapter. I read somewhere that I need to harden the voltage regulator for the offroad vibration, but I can't find the info again. Is that the small donut thing with the wire wrapped around it? Do I just encase it in five minute epoxy, or RTV? Share this post Link to post Share on other sites
StillCrazy Posted December 7, 2004 Mine has'nt needed hardening. That thing is an RF choke and probably doesn't need hardened either. I did run wires directly into mine and hook them to the circuit board difrect wiring it to power rather than deal with the intermittent power of a vibrating cigarette lighter.... Hope that helps Share this post Link to post Share on other sites
Weeeeee Posted December 7, 2004 I pulled my odometer off, and used the mounting holes and rubber bushings, to mount the bracket that holds my female connection. So maybe I wont get a lot of vibration. If I do, I guess I could just return it and try again. Share this post Link to post Share on other sites
Noble Posted December 7, 2004 I have a Garmin Etrex, with the cigarette lighter adapter. I read somewhere that I need to harden the voltage regulator for the offroad vibration, but I can't find the info again. Is that the small donut thing with the wire wrapped around it? Do I just encase it in five minute epoxy, or RTV? The power supply is inside the cigarette lighter plug. Take it apart and use just a little RTV to stabilize the circuit board. Share this post Link to post Share on other sites
MoonBeamer My Ride Posted December 7, 2004 I haven't had any problems with my setup. I have an etrex Ledgend and have a cig plug that hangs loose behind my headlight. I plug the adapter into it and the only problem i have had is when the plug got rusted some. I can see how you may want to waterproof the adapter with some RTV though. I have ridden in rain with mine and no problems yet. Share this post Link to post Share on other sites
