foxracing My Rides (3) Posted December 8, 2004 Is the 03 RM125's rear brakeset (caliper, pedal, master cylinder) a bolt on fit to the DRZ? Thanx! Share this post Link to post Share on other sites
hardrider Posted December 8, 2004 03? Not too sure. I'm sure someone else here will know. 99-01 POSITIVE 😢 Share this post Link to post Share on other sites
alophind Posted December 8, 2004 Is the 03 RM125's rear brakeset (caliper, pedal, master cylinder) a bolt on fit to the DRZ? Thanx! Why would you want to do that ? Share this post Link to post Share on other sites
hardrider Posted December 8, 2004 99 onwards RM use a 240mm rotor. DRZ and pre 99 RM use a 220mm rotor. Bigger rotor, stronger braking effect. Also big rotors look cool 😢 Share this post Link to post Share on other sites
Wayward Son Posted December 8, 2004 the only parts that are upgrade are the rotor and caliper carrier. Share this post Link to post Share on other sites
foxracing My Rides (3) Posted December 8, 2004 I'm juz wondering if it will fit. I've taken the carrier for myself already and a new Braking 03 RM wave rotor cheap from ebay. If the 03 RM rear brakeset will fit on a DRZ, I could pass it on to whoever needs it here in Singapore. So will it fit a DRZ? Master cylinder, pedal, brakelines, caliper, pads the whole lot... thanx! Share this post Link to post Share on other sites
Wayward Son Posted December 8, 2004 everything but the pedal. Share this post Link to post Share on other sites
foxracing My Rides (3) Posted December 9, 2004 😢 Doubt ppl will trash up their stock DRZ pedal right? Big thanx for the heads up burned. Hope it will become useful for someone else. Share this post Link to post Share on other sites
ROUNDEYEHELMETHEAD Posted June 30, 2007 i realize this is old. is the 99 - 01 rm rear brake pedal definetely the same as the drz? Share this post Link to post Share on other sites
foxracing My Rides (3) Posted June 30, 2007 No they are not. Share this post Link to post Share on other sites
ROUNDEYEHELMETHEAD Posted June 30, 2007 No they are not. thanks for the reply. the part numbers for the pedal(end piece only) are the same 43110-43d00 the part numbers for the arm are slightly different. 2000 rm 250 is p/n: 43120-37e00 2004 drz400 is p/n: 43120-29f10 "hardrider's" post(2nd one from top) stating the '99-01 is the same is incorrect then? Share this post Link to post Share on other sites
