malibu3 Posted December 9, 2004 Well I have had my 250X now for a couple months. I have only cut the top airbox and installed the JD Kit. I have put in a t-handle easy adjust fuel/air screw. I am kinda at a lost at this point figuring out what i need to do to get my bike back where it needs to be. When I first had it, other than running really lean, it pulled good from the botton, roll on was pretty good. Now if I roll on to fast, I don't mean just hammer the throttle, the bike will hesitate then give a pretty good backfire and go. Is this a lean/rich condition. Which way do I need to go to start with, I am kinda at a lost. 😢 I still have the factory pilot jet in, temps right around 50 degrees................any thoughts? Thanks in advance for your help. Malibu3 Share this post Link to post Share on other sites
James_Dean Posted December 9, 2004 The condition is probably lean from the description. Try 1 step richer clip position, and if you need another option, then the blue marked needle in the middle clip position. Fuel screw should be near 2 1/4 turn sout from seated. Thanks, James Share this post Link to post Share on other sites
