xr50 rebuild
So hydro-locked his 2003 XR50. Need to rebuild. The rod is bent slightly. WHAT all parts do i need to replace to get this thing running again. I am not interested in any big bore kits, just want to leavi it stock. Thanks
Go to Beatrice Cycle , scroll down to the XR50/XR70 replacement crankshaft assembly, part# 200067. You'll need to get a complete gasket set, and you'll be good to go, to remove and replace the whole crank assembly. Clymer makes a detailed, step-by-step Manual, you can find it HERE
