Magura Hydro Clutch Installation
Does anybody have any tips on installing a Magura hydraulic clutch on a DRZ400E? I'm having a little trouble getting it to work right. Should there be tension on the clutch arm when it is engaged? 😢
Umm, when it's engaged,, there better be tension on the arm,, other wise it would not be engaged 😢
There should be free play at the arm/clutch engagement with the lever at rest.. just like with a cable.
You set that by placement of the arm on the spline shaft,, and the spoke nipple looking part on the end of the slave cylinder.
😢😢 just a few mm at the arm once the freeplay is taken up. Total movement at the arm from installed resting position to full slave cylinder stoke is about 10~15mm. Id have to look and measure tonight to be real sure,, So that is just an educated guess right now.
