atc350x Posted December 15, 2004 I have an 85 Kawasaki klr 250 and i need to know what the timing specs are for the dohc because i cant seem to get it right the more info i can get the better. Thanks Share this post Link to post Share on other sites
12bridn Posted December 16, 2004 Dunno, but it is probably the same as every other year KLR250, the engines are all the same. Share this post Link to post Share on other sites
Fire Escape Posted December 17, 2004 The manual says that it's a "no Maintenance" system. Should be 10 BTDC at idle and 35 BTDC at 3000 rpm. To quote the book "If the ignition timing is suspectable, check the CDI unit and the pickup coil" Share this post Link to post Share on other sites
