freerider_australia My Rides (2) Posted December 15, 2004 Any one have info on the correct fork oil type and amount?i will drain mine and measure amount.just interested if other people have adjusted height and how much effect it has had Share this post Link to post Share on other sites
Indetrucks Posted December 15, 2004 I hear anything from 15-30 wt is good. The heavy stuff for stiffer suspension.. 30 may be on the extreme side though... You can also mix the two together to get something in the middle. example. 20wt + 25wt = 22.5wt.. I think 20 or 25wt is sufficient and I'm 175 lbs.. It's really preference. DO not over fill or you're gonna have blown fork seals on your hands. Share this post Link to post Share on other sites
