Railroader Posted December 15, 2004 I went to pull the tank while ago to do my plug swap, and the fuel line was stuck on the petcock fitting. I gripped the hose gently with a pair of pliers and twisted just a little bit to break it loose......and the WHOLE BRASS FITTING came out of the bottom of the petcock, along with the hose. This surprised me as I have removed stuck hoses that way forever. After separating the hose and the brass fitting, I tapped it back into place using a piece of leather and a screwdriver handle. No leaks, runs fine, but I don't know if I tore anything up or not.......Does anyone else know? I also rubbed a tiny bit of cup grease on the fitting so maybe it won't happen again. This was a new one on me, so I thought I'd share..... Share this post Link to post Share on other sites
Wayward Son Posted December 15, 2004 happens all the time.you did fine. Share this post Link to post Share on other sites
Railroader Posted December 15, 2004 happens all the time.you did fine. Burned, Somehow, Sometime, one of these days I'm gonna do something to help YOU out 😢😢 ....Thanks for being there, man. 😢 Share this post Link to post Share on other sites
jha07 Posted December 15, 2004 I've always been disconnecting that hose on the carb side. I hope that fitting is sturdier than the tank fitting. Share this post Link to post Share on other sites
Noble Posted December 16, 2004 Happens all the time. Mostly with pot metal (cast zinc) fittings. I usually use a drop of Loctite when I put the brass back in, but as long as it dose not leak you are fine. A better technique is to push the hose off rather than pull it off. Even doing that, the brass sometimes comes out especially on old stuff. Share this post Link to post Share on other sites
anathema Posted December 16, 2004 Agree about pushing the hose off. Its like a chinese finger trap. If you pull it the tube stretches and gets thinner/tighter. If you push it it gets fatter/looser and comes off much easier. In my experiance anyways. Happens all the time. Mostly with pot metal (cast zinc) fittings. I usually use a drop of Loctite when I put the brass back in, but as long as it dose not leak you are fine. A better technique is to push the hose off rather than pull it off. Even doing that, the brass sometimes comes out especially on old stuff. Share this post Link to post Share on other sites
