slipping clutch
I believe my clutch is slipping. When I am in 4th or 5th gear and pin the throttle the engine rpm increases and the bike does not accelerate much. This only happens in these two gears. Is this the beginning of my clutch going out? What clutch plates do you recommend replacing it with? I am thinking about sticking with factory Honda as this is still the original clutch! Any info or pointers would be appreciated. 😢
I'd bet it's more your springs than your plates. Stock XR plates will last longer than the saggy springs. 😢
