powdercoat or paint
i wanna get my rims frame and subframe all blakc i just dont know which way to do it pc or paint? i want to get them all done the same way. i have easy acess to a paint booth and i could go get some paints i might have to go and get a spray gun though. i have just heard alot of concerns about sand blasting and that it can get into the frame and get passed through the motor through the oil and ruin it what should i do?
powder coat lasts a heck of alot longer and also looks better too.
2-3 cans of Krylon costs about $9.00 and you can touch up problems yourself.
I vote for powdercoating. The durability of the finish is unmatched. Be sure to remove any bearings or bushings of any kind before taking it in. The powdercoating is done in an oven and will ruin seals etc. 😢
Also be sure to put bolts that you dont want in the threads so that you can take them out when done. And plug up all the holes and if it's a yammie, throughly clean out the oil tank.
The only bad thing about Powder Coating is that after a while it cracks and is VERY hard to repair without it looking bad. It doesn't cost too much and looks great.
I would go with PC, I used to shoot powder and It is very durable. Check out my 450 in my garage, the frame is powder coated. It shouldnt crack if done correctly but will chip if hit with sharp rocks. To help avoid this have them shoot the color and then put a clear over it, the clear is more flexible and will add a shine like you wouldnt believe. If you have a Yamaha with an oil resivoir in the frame have them either burn off the old paint or chemical dip it (providing they have a burn oven or dip tank) I have done lots of custom stuff, I wish I still did it for a living, except it didnt pay too well. I would like to bead blast the frame (a type of sand blasting with glass bead media) then just throw a clear over it, it comes out like a silver sparkle.
If you PC make sure you remove everything like suggested above and also make sure you mask all mounting area for the motor, swing arm and other components or you will have a hard time getting them back on and will have to file your new paint job.
I understand that you can touch up Krylon yourself, but man PC looks so good. I think, bang for your buck you will get better results with PC. I think in this case your going to get what you pay for.
Powder Coat The Frame And Strip The Rims And Have Them Anodized Black. They Look Trick And Is Very Durable. Just Make Sure If You Go With Anodize On The Rims That The Anodizer Adds Uv Protectant Into The Mix, Otherwise The Color For The Anodize Will Fade To Nothing In The Sun, It Is Still Anodized But With No Color. The Additive Will Make It So They Won't Fade.
Find a powder coater that will fix damaged areas. The shop where we get our powdercoating done will touch-up any damage for no charge. They know that MX bikes get beat up, so they don't have a problem with fixing scuffs and such.
Dan.
