rookie517 Posted December 16, 2004 the dr650 is using CV carb which is the same as DRZ-S (i presume) after removing tank and doing some work on the bike, i put back both the fuel line and the vacuum line. but the problem now is, in "ON" position, the fuel is not drawing in by the carb when engine is running(still can idle till carb run out of gas), only when in PRI position, i can see the gas moving(bike can maintain idle in this position) i wonder what is the problem?? 😢 just now, even though i purposely pull out the vacuum line, the bike still can idle for quite sometimes before it dies off. advice pls 😢 Share this post Link to post Share on other sites
Spud786 Posted December 16, 2004 sounds like the diaphram in the fuel tank petcock is BAD Share this post Link to post Share on other sites
hardrider Posted December 16, 2004 Ahhh.... so this is your new toy 😢 Share this post Link to post Share on other sites
rookie517 Posted December 17, 2004 nah, my friend 😢 Share this post Link to post Share on other sites
sahkomies Posted December 17, 2004 the dr650 is using CV carb which is the same as DRZ-S (i presume) advice pls 😢 I believe its different. DRZ has BSR36 and DR has BST40 which is also CV type. Share this post Link to post Share on other sites
rookie517 Posted December 17, 2004 ya is a different carb, only know is a CV carb so i guess it should be working the same principal?? Share this post Link to post Share on other sites
sahkomies Posted December 17, 2004 so i guess it should be working the same principal?? That's my quess as well. I don't know if you can read swedish but there is a site which gives some advice on tuning DR650. http://home.swipnet.se/~w-37577/tunedr.htm In case swedish is difficult, it basically says that get an aftermarket exhaust, open up the air box and rejet with #45 pilot and #145/148 main. Share this post Link to post Share on other sites
nebulaz Posted December 17, 2004 rookie's new toy is just as sweet as his previous bike..hardrider..hehe..such tender loving care from a such knowledgeble owner is wat evrybike needs.. Share this post Link to post Share on other sites
BW350DRZ400S Posted December 17, 2004 Check it on reserve, and check fuel line for cracks/splits (air leaks). 😢 Share this post Link to post Share on other sites
rookie517 Posted December 17, 2004 on the CV carb system, we only got ON, OFF and PRI. no RESERVE but we do check for any air leak already, no clue... 😢 Share this post Link to post Share on other sites
joeizdaman Posted December 17, 2004 nah, my friend 😢 ahah! my friend's??? which u would be taking over rite? hehehe : 😢 Share this post Link to post Share on other sites
rookie517 Posted December 17, 2004 no lah, my friend just bought it. Share this post Link to post Share on other sites
BW350DRZ400S Posted December 17, 2004 OK what were the two of you doing to the bike and what year is it? Share this post Link to post Share on other sites
rookie517 Posted December 18, 2004 erm, it should be a 98 or 97 he just had the bike, so was doing some oil change (oil filter as well) and also the plug but when putting back, the problem arise.. Share this post Link to post Share on other sites
hardrider Posted December 18, 2004 rookie's new toy is just as sweet as his previous bike..hardrider..hehe..such tender loving care from a such knowledgeble owner is wat evrybike needs.. So what is his new toy? 😢 Share this post Link to post Share on other sites
BW350DRZ400S Posted December 18, 2004 I have a 97 DR 650, I do not need to remove the tank to change the spark plugs and oil. It may-be new to him because it has some problems. Remove petcock clean and replace. 😢 Share this post Link to post Share on other sites
rookie517 Posted December 18, 2004 I have a 97 DR 650, I do not need to remove the tank to change the spark plugs and oil. It may-be new to him because it has some problems. Remove petcock clean and replace. 😢 thanks, we will try it out 😢 Share this post Link to post Share on other sites
