jakemad Posted December 16, 2004 Hi all, I am having my suspention revalved and they are recomending softer springs front and rear ($200). They said that the CRF250 has the softer spring rate for my wieght. any one on the 250 wieghing 170 to 200lbs should have the heavier spring rate that is in the 450. I'm looking for someone who is willing to trade front and rear springs with me. I live in San Jose, CA but am willing to ship. Share this post Link to post Share on other sites
cjlan66 Posted December 16, 2004 What spring rate do you have? Share this post Link to post Share on other sites
Heckler My Ride Posted December 16, 2004 Yea, Whats the spring rate. Im local in San Mateo. Share this post Link to post Share on other sites
jakemad Posted December 17, 2004 CRF450R has: .47 front 5.5 rear CRF250R has: .45 front 5.0 rear The X models have lighter rates, but I'm not sure what they are. Share this post Link to post Share on other sites
yblocmx Posted December 17, 2004 Its actually a 5.3 on the rear for the crf250r. Also, I would go with new factory connection springs, they are supposed to be the best from what I hear. Share this post Link to post Share on other sites
jakemad Posted December 17, 2004 My bad on the spec. I got it from a suspention web site, not the manual or honda. This may be more trouble than its worth. Do you know if you can remove the fork springs without replacing the oil and just how hard is it to remove them. I've only disassembled conventional style ones. Share this post Link to post Share on other sites
TheWeez Posted December 17, 2004 My bad on the spec. I got it from a suspention web site, not the manual or honda. This may be more trouble than its worth. Do you know if you can remove the fork springs without replacing the oil and just how hard is it to remove them. I've only disassembled conventional style ones. If you're removing your springs, you definitely want to change your fork oil while you're in there. Oil will cost you about $5.00 and if you've never done it, you need to. Share this post Link to post Share on other sites
Guest penguin Posted December 17, 2004 I have the stock springs used for 1 ride before I changed them. My son is over 200 pounds and could use some heavier springs on his CRF250R. I am in Texas Share this post Link to post Share on other sites
