digitaldan Posted December 16, 2004 I have read a number of posts of people telling how to pull wheelies by "clutching" the bike. But on my DRZ at least clutching the bike in first at any revs has no real effect on lifting the front, I had the same with my last dirtbike (XR250). My only bike that had quite a response to having a stab at the clutch was my VFR streetbike. So now I'm wondering if my clutch needs replacement or maybe just adjusting. My clutch takes fairly late but there is no shuddering or slippage at pull away so I don't think it's past it's sell by date. Is there any procedure in adjusting the clutch to know if it's correct ? Share this post Link to post Share on other sites
Railroader Posted December 16, 2004 If you have ANY clutch left, it oughta loft the front easily.... 😢 Share this post Link to post Share on other sites
Squidward Posted December 16, 2004 I agree.. my bike would spit me off the back if I tried to clutch a wheelie in first at anything over a few grand rpm. 😢 Share this post Link to post Share on other sites
Spud786 Posted December 16, 2004 Are you running a completely stock bike with 15/44 and snorkeled airbox? I know with snorkled airbox slipping clutch in second it was pretty pathetic, but first gear should pop up. Share this post Link to post Share on other sites
anathema Posted December 16, 2004 Just rev her into the middle upper range with the clutch in on the edge of your fingers...then let it slip off the edge. You will either end up on your back or on your back wheel 😢 Share this post Link to post Share on other sites
Noble Posted December 16, 2004 There is a lot of technique to doing good wheelies. Something I have never been very good at. But with a clutch, by god you can loop out a moped. Stand-still or moving: clutdh it, rev it and feed the clutch agressively and something is going to happen. Share this post Link to post Share on other sites
slide Posted December 16, 2004 Move back on the seat some. Share this post Link to post Share on other sites
PowerStroke Posted December 17, 2004 Is your chain on? Sorry Share this post Link to post Share on other sites
millemg Posted December 17, 2004 Could you post a video clip please 😢😢😢 Share this post Link to post Share on other sites
digitaldan Posted December 17, 2004 No seriously there is very little rpm increse when I clutch my bike. I have the snorkel removed and run a 145 main with a 2x3 hole 😢 I don't know what's the matter, as I said clutch does not slip and bike pulls fine but it's impossible to wheelie by using the clutch 😢 Share this post Link to post Share on other sites
slide Posted December 17, 2004 Hold it a second. So you say you're running down the street and you pull your clutch lever in and there is no rpm increase with steady throttle? How do you start out from a dead stop then? Share this post Link to post Share on other sites
millemg Posted December 17, 2004 Lol...... 😢 If he is screaming down the road in first at high revs, he's probably right, no increase in revs when dipping the clutch, but it certainly ain't gonna wheelie...!!!! Terrifies me thinking about it 😢 :cry: 😢 Please post a video 🤣😢 Share this post Link to post Share on other sites
slide Posted December 17, 2004 It didn't occur to me that he's trying to wheelie at redline in gear. 😢 If so, I think we figured out the problem. 😢 Share this post Link to post Share on other sites
millemg Posted December 17, 2004 It sounds that way to me.......... OK Dan......Try this...............no clutch, no revs, no first gear................ http://get.filehosting.org/wp9980.avi 😢 Share this post Link to post Share on other sites
CrashMW Posted December 17, 2004 Yeah, I have the same problem. The bike simply refuses to wheelie. It is impossible, and do not let anyone tell you otherwise. 😢 BTW, what is a clutch anyway? MW Share this post Link to post Share on other sites
a109drvr Posted December 17, 2004 No seriously there is very little rpm increse when I clutch my bike. I have the snorkel removed and run a 145 main with a 2x3 hole I don't know what's the matter, as I said clutch does not slip and bike pulls fine but it's impossible to wheelie by using the clutch First of all, for us to actually help you we need to know what you mean by "clutching the bike". If you mean while moving you pull in the clutch lever and release it quickly, that won't help get the wheel off the ground. From your first post you mentioned a stab at the clutch. The only time I use this technique is when coming out of a corner in the dirt and the bike bogs because I'm a gear too high. It gets the rpms up and when you release the cutch lever the rear tire usually spins. In first gear or second a stock S can wheely with no clutch use. Just get the bike moving slowly(not wide open throttle), move your weight toward the rear of the seat and open the throttle quickly. See millemg's movie. Third gear might need some clutch to wheely. With the bike moving 20mph or so (won't work from a standstill) in third gear, pull in the clutch lever, open the throttle all the way and release the clutch lever quickly but smoothly while pulling on the bars. Again, this is not a "slap" at the clutch, you have to hold the lever in while giving it throttle and once the rpms are high enough smoothly release the lever. I agree with everyone else, you try this in first gear, especially from a stop and you will land on your back. If you do, I want to see a clip of it as well 😢 Share this post Link to post Share on other sites
Squidward Posted December 17, 2004 Someone's been playing too much MX Madness 2.. - The clutch clutches.. and that's it. No shot of NOS or extra power.. it's just a clutch man. Share this post Link to post Share on other sites
digitaldan Posted December 17, 2004 Ok so if someone talks about clutching the bike does he mean a) riding along in first or second gear at normal revs and just quickly clutching the lever, this is what I try or 😢 pulling in the clutch and let the revs rise and then let the clutch go ? The only reason I asked was because my roadbike would pull a wheelie with me just taking a quick "stab" at the clutch lever, it felt alot more responsive than my DRZ does doing the same and it was only a 400 sportsbike so there is not alot of hp or torque at hand. Share this post Link to post Share on other sites
millemg Posted December 17, 2004 You scare me 😢:cry:😢😏😢 Pleeeeeeease post a video 😢🤣 Share this post Link to post Share on other sites
Spud786 Posted December 17, 2004 ((The only reason I asked was because my roadbike would pull a wheelie with me just taking a quick "stab" at ))) Your talking alot more horse power. You were experiencing so much horsepower that little stab is all it took. Less power bikes take more technique. Learning that technique will aid you grately on control of larger bikes. Share this post Link to post Share on other sites
