ecox Posted December 17, 2004 My 04 KX250F has hesitation when the throttle is snapped open, rolls on fine starts fine, air filter clean. I adj the fuel screw 90deg richer (ccw) no improvement. Any suggestions? Thank You Share this post Link to post Share on other sites
mxmike117 Posted December 17, 2004 if you try snapping the throttel fast, all bikes will have a slight hesitation. Even mine does that... Its normal. Share this post Link to post Share on other sites
ecox Posted December 17, 2004 This more than slight, and is very noticable exiting turns, our 05 rmz does not do it. Share this post Link to post Share on other sites
purdyfast Posted December 17, 2004 My 04 RMZ had a huge hesitation, kind of like a hicup when the throttle was rolled on fast. I went to a 45 pilot jet and end of problem! It's easy to change just loosen carb boots , roll it over a little bit so you can access the bottom, take the large nut off the bottom of the bowl and the jet is right there. Let us know what you end up finding. Share this post Link to post Share on other sites
Guest penguin Posted December 17, 2004 when I had my KX250F it had a bit of hesitation and my current CRF does to. It is the nature of the 4-stroke and they all have it to some degree. You can fiddle with the accelerator pump timing, pilot screw, pilot jet and needle position to make it better, but I could never make it completely go away Share this post Link to post Share on other sites
suzookrider Posted December 17, 2004 Adjust the throttle cable...Mine did it also, no it seems better that I adjusted the cables Share this post Link to post Share on other sites
mvlcorona Posted December 17, 2004 Try adjusting the throttle cable, and PC jetting specs for your altitude. Share this post Link to post Share on other sites
ecox Posted December 19, 2004 Throttle cable adj took care of it. I already had a 42 pilot(1 step up) one of those cables must pull the pump lever. It seemed like a new bike, really snapped to life. Thanks all for the help. Share this post Link to post Share on other sites
