Talon Hub and Speedo drive???? Burned..Bronco..Anyone???
Ok, I just want to make sure that I don't screw up before I get too rambunctious with this new wheel....When I put it back together, I aligned the plastic tabs on the speedo drive 90 deg off from the tabs on the hubs and snugged it all up...Put the caliper back on, and hand-spun the tire. Speedo seems to work (spun it up to 10 with the ign. on) no popping or creaking or rubbing....Anythng to look at before I tighten it all up?????
sounds fine
Good, as soon as I double check it all...at long last.....I'm gonna go try it out...Thanks again. 😢😢
