Jaycen Posted December 18, 2004 where and how? do I have to remove that 17mm bolt at the bottom? in the manual it says i need a special tool, and that special tool is 118$ from my dealer....please help, i sat and looked at the carb for ever. Share this post Link to post Share on other sites
Suz459 Posted December 18, 2004 Remove the bolt on the bottom of the carb and the pilot jet is just to the side & up of the main I think it' like a 6mm no problem. Share this post Link to post Share on other sites
calidunes Posted December 18, 2004 you need a 6mm 1/4 inch drive socket, probly a couple bucks at sears. Share this post Link to post Share on other sites
fletch7276 Posted December 19, 2004 couple other suggestions.. there will actually be three jets clustered together in the middle of the underside of the carb. the pilot jet will be the long slender jet, about an inch long or so, and it will be stamped with a size on the side. you can either access the jets by taking the 17mm cap off, or just pull the four screws out that hold the float bowl. the latter might be a better way to get yourself familiar with digging into a carb in the future. Share this post Link to post Share on other sites
Suz459 Posted December 19, 2004 Thats a good suggestion, I did the exact same thing just so I knew exactly what I was looking at. Share this post Link to post Share on other sites
