bdeezy400 Posted December 18, 2004 the gear that drives the waterpump on my 01 yz250f broke like three teeth off. i didn't notice it until the clutch case gasket started leaking and i went in to replace that. there was a big chunk of the gear laying in the bottom of the case. anyway my question is what should i do to make sure that busted gear isn't floating around in my engine? the bike is probably due for a top end and valve adjustment. i would rather prevent something from breaking before i end up with a $3000 parts bill for a $3000 bike. any suggestions would be great. Share this post Link to post Share on other sites
SUnruh My Rides (2) Posted December 18, 2004 follow the manual and remove the cases to get to the water pump shaft. replace all parts necessary after a proper inspection. flush the lower end and all oil lines. inspect the filters and screen. you might as well replace the water pump seals too. here is a question i have for you: did your water pump shaft have the retaining circlip on it? as mine did NOT from the factory. Share this post Link to post Share on other sites
bdeezy400 Posted December 19, 2004 i have the circlip and everything looks ok on the waterpump im just worried about a piece of that gear floating around in my top end Share this post Link to post Share on other sites
Barracuda163 Posted December 21, 2004 I have broken that gearbefore, but it caused no harm. I was putting the cases back together and forgot to engage the gear before mating the cases up, and I heard a loud TIIINNNKK! i was so mad at myself, I should have known better, but beofre I knew it, dad and i had the thing welded up, stuck it in the lathe to clean it up a bit and I was riding. Of course I ordered a new $60 shaft and replaced it as soon as I got the new one. Share this post Link to post Share on other sites
