Hourmeter / tach
Anyone ever put an hour meter on their bike? This one looks pretty decent Sendec . I like the fact you get a tach with a maximum RPM memory.
i dont know how much that one is, and was only interested if you could reset the time.... i bought one from sears for 25.00 (hours only) and it works fine . just make sure you use the bolts to the frame for a ground, otherwise it wont work.
I have the regular Sendec hormeter on mine from Sears too and it works great.
You don't have to drill holes in your frame though, I mounted mine with velcro. MOUNT
Wen you connect the wire it has to be like THIS
i put mine around the wire and nothing worked then i saw a post on here about the grounding with the bolts...wish i''d seen yours first... oh well i still works and now i know.
thanks
david
That one looks NICE! I have a more regular Sendec on my X. It only measures up to 9999 rpm and has no max RPM recall. It cost $30 or so on Ebay and I mounted it on the upper right frame spar, just below the shroud using a tie wrap. It seems like a well built device. I think I'll look into the one you found.
