marcusmoberg   Posted December 18, 2004 I have a stripped out engine drain allen bolt. Can anyone give me any ideas? 😢 Share this post Link to post Share on other sites
Farmr123 Â Â Posted December 18, 2004 Did you strip the head, or the threads of the bolt? If it is the threads, they make re-threader kits, or you might be able to get a one-sized bigger bolt, and get it to work. If you stripped out the head, do you have a Dremel-type tool? You can carefully cut a slot in it & try a big screwdriver, or if that doesn't work, a hammer and punch. Put the punch against the bolt on the outside of the head, and use the impact to try to turn the bolt & break it loose. Once you get it to move, you should have it made. Share this post Link to post Share on other sites
HalfNutz   Posted December 18, 2004 You can get yourself a set of those bitchin' left-handed drill bits with easy-outs built right into 'em at Sears. They work great. Most of the time the drill bit itself is what ends up removing the stripped bolt, before it even gets deep enough to use the easy-out part. Here they are, they call them power extractors. Power Extractor - Small Set Power Extractor - Large Set Share this post Link to post Share on other sites
gcvt   Posted December 18, 2004 Check out http://www.timesert.com - used one on a KLX300 with a stripped out drain bolt and it worked very well. Share this post Link to post Share on other sites
250Thumpher   Posted December 18, 2004 If the head of it is stripped, you may be able to get a hacksaw blade in there to cut a slot and take out the bolt. Trick is on getting the oil filter cover (I'm guessing thats what you stripped) loosen the two uper 8mm bolts first, then the allen bolt last. Share this post Link to post Share on other sites
vetplus40 Â Â Posted December 19, 2004 You might be able to chase the threads on the bolt and the bolt hole. I was able to repair mine with this method. In fact, I changed my oil and checked my filter today. I chased the threads again and it cinched up just fine. Share this post Link to post Share on other sites
