CRF 230 - Oil drain plug location and oil capacity?
I know I should "check the manual", but I do not have one yet ?
Can someone point out where the drain plug is for the oil?
How much oil does it take to fill it up after an oil change?
Did I read correctly in another thread that you have to take the crankcase cover off to clean the oil filter?
Thanks for all the help!
It's on the left side of the case by the shifter.And it takes 1.1 us quart, and to check the oil level it should be on the top mark without screwing the dip stick into the case. the manual say's that you do not have to clean the centrifugal filter until you have over 1,200 miles on it.
  • 3 years later...
Where is the centrifugal filter located????
same way with the 150 i was so confused when i got it cause i was used to the plug at the bottom and ya i changed it last weekend it took me 2 hours and then i finaly just said screw it and i just crancked down on it and then oil drained out
