trpw Posted December 19, 2004 I bent the stock handlebars first day out and now will install Renthal CR Low bend. When I removed the bolt holding the ugly red plastic (that didn't break) on the clutch side, I see the bolt has a collar that will leave it extruding out the top of the clutch perch when I reinstall it. That wouldn't be perfect to my eye. What's the fix? Can I get a new bolt easily? Shall I get this one machined to my demanding standards? Thanks. -Tedd Share this post Link to post Share on other sites
mcdrz Posted December 19, 2004 Here you go: 1. Brake Lever Bolt - part #90114-166-006 2. Brake Lever Rubber Boot - part #53176-ML3-791 3. Clutch Lever Bolt - part #90114-428-870 4. Clutch Lever Rubber Boot - part #53177-430-000 Plus you need locking nuts and its a done deal. Share this post Link to post Share on other sites
trpw Posted December 19, 2004 Thanks. I have the bark busters to install and will get the proper bolts. I thought all the new bike came with those flimsy plastic handguards. Obviously not, or not everyone thnks they're ugly. Share this post Link to post Share on other sites
jws Posted December 20, 2004 i did this on my xr 650 a couple of years ago 😢 check out this link jeff 😢 Share this post Link to post Share on other sites
xrMike Posted December 20, 2004 I did the same thing a couple years ago to my XR4 when I replaced the stock bar guards/plastic with aftermarket ones. Just order the parts listed above from your Honda dealer. Those bolts and boots fit perfectly, and look good too. Share this post Link to post Share on other sites
kerrdogxr400 Posted December 20, 2004 any one know of a part number or make of shorter shift levers for the brake and clutch for my '03 XR4? I've cut my bars down an inch each side now my stock levers stick out, which defeats the purpose of the Aceribis brush guards I have on. Any advice? Share this post Link to post Share on other sites
jws Posted December 20, 2004 any one know of a part number or make of shorter shift levers for the brake and clutch for my '03 XR4? I've cut my bars down an inch each side now my stock levers stick out, which defeats the purpose of the Aceribis brush guards I have on. Any advice? i picked up a 2 pack of shorter levers made by trick for $6.99 at the local cycle shop - i had the same problem with the stock levers hitting the POS aceribis rally pros. jeff 😢 Share this post Link to post Share on other sites
mcdrz Posted December 20, 2004 Moose competition levers (rubber grip insert)work great, however they can't compete with the Trick price stated above. Share this post Link to post Share on other sites
xrMike Posted December 20, 2004 I think Moose makes "shorty" versions of the brake & clutch levers. I have the all-black ones. Share this post Link to post Share on other sites
mikejk Posted December 20, 2004 Nice timeing, I just took the stock guards off yesterday and was going to post the same question today. As for the shorter levers..get out the Dremel..cut the ends off and sand them smooth..15min...no extra $. Share this post Link to post Share on other sites
AHRMA17L Posted December 2, 2005 Here you go: 1. Brake Lever Bolt - part #90114-166-006 2. Brake Lever Rubber Boot - part #53176-ML3-791 3. Clutch Lever Bolt - part #90114-428-870 4. Clutch Lever Rubber Boot - part #53177-430-000 Plus you need locking nuts and its a done deal. Thanks for the part numbers, and hats off to Thumpertalk for having these forums to help us keep our bikes sano! Share this post Link to post Share on other sites
GUMBYXR400 Posted December 2, 2005 Ditto on the dremel/hacksaw. I cut my levers to fit behind my bark busters and also grinded the part where your fingers grab for a little better feel in the mud and wet. Works great and free. Share this post Link to post Share on other sites
schuon Posted December 2, 2005 I have aftermarket handguards on my yamaha warrior, so i just used the old brake lever bolt from my warrior in my XR, fit perfectly. I put aftermarket guards on the xr so i didnt want that brake lever bolt sticking up and cutting me when i crash, which is guaranteed to happen. Share this post Link to post Share on other sites
