Is this the correct baja shifter?
Got an extended shifter from Baja Designs as an early christmas present. Noticed two problems when attempting to put it on: 1) bolt is on opposite side (top instead of bottom for stock). It looks like it will clear though...maybe. 2) The hole seems a bit small - doesnt want to slide over the spindle. May be able to open it up more, but dont want to damage it if this is the wrong one.
So...can anyone tell by this pic whether Baja sent me the correct part? The label on the bag says "70-0002 DRZ/KLX400 extended", but a piece of paper that came with it in the bag says "KLR 650 87-04"
shifter pic - click here
It LOOKS like you been swindled. My BD shift lever drops down a bit from the spline then kicks out over the mag cover then bends parellall on the same plane. The one you got seems to have another bend in it at foot knob. See how your stock one doesn't do that?
Wrong part.
damn! baja designs is 0 for 2 with me...2 orders and 2 problems! 😢
thanks for the info guys...looks like i'll be shippin it back. at least i don't need it right away...
