valve clearance question??
hey guys, i'm new to the forum. thought i would ask you a question. i checked the valves on my r model today. i have .004 on the exhaust, and .010 on the intake. i know this is a bit tight as per the manual. will i be alright without adjustments??? thanks for your opinions.
Are you sure you didn't transpose the measurements? If your intakes measured 0.004" and exhausts measured 0.010", you're on the tight side, but within spec; otherwise, you really need to reshim.
inlets are the ones closest to your carby, so your inlets would be 0.004" and exhaust 0.010" They are still in spec so you don't need to shim yet. Check them every ride and shim when they go out of spec.
