Please help, jetting a stock 250X
Hello, and right off the bat let me ask apologies if this information had been covered. I am one of the unlucky few who has dial-up internet, and search times are getting longer and longer! :cry:
I own a 2004 250X, live at sea level (about 1.5 hour drive from Atlantic City), and have a terrible bog off-idle. (It will downright stall out if I try to hit the throttle hard from a dead stop, and it also does this with the bike in neutral).
I am interested in the JD jetting kit, and would appreciate a nudge in the direction of the right jets to try starting out with. The carb and rest of the bike are still completely stock. I am not yet interested in cutting the airbox, or modifying the exhaust -- I'd like to do this in steps, first getting rid of the bogging problem with rejetting (if possible).
Can someone help this new-comer jetting for the first time?!
Also, will I need any jet wrenches? What size (6 or 8 mm) and what shape?
One last question: JD kits don't come with any leak jets it seems. Is this an important jet to change when rejetting?
Thank you very much, I appreciate this web site and your information.
I wanna get this thing ripping and roosting!!! :cry:
matt
Southern New Jersey (lots of woods here).
The first mod I did to my 2004 was the JD kit and I love it. I have only cut the top of the air box and followed the kit instructions and it worked great. I have since installed a 42 pilot and it helped even more on the bottom end. If you have a problem or question JD will answer you on the Jetting Forum.
Would you recommend also changing the main jet? Or should I just change the pilot jet for now? :cry: How about the leak jet -- is that one that matters much?
I was thinking of going to the next size up on each jet, so long as I'd already have the carb apart. The leak jet, though, taking it up a size will mean "less" gas is applied to the intake from the accelerator pump... at least I think...
Is that right?
Thanks for your time,
Matt
I have a CA bike and run at about 3,000 to 3,500 foot in elevation at about 50-70 degrees. Right now I am running a 155 main, 42 pilot, JD blue needle on the 4th position and 2 turns out on the fuel screw. Lower altitude and/or warmer calls for richer jetting, higher elevation and/or colder calls for leaner jetting. JD's kit has excellent recommenddations for all conditions.
Does anyone have the instructions for moding the airbox and for rejetting instructions online for the crf250x
  • Similar Content
    • By Nicturner
      Hi fellow thumpers,
      firstly if there is other threads on this topic I apologize.
      i have a 2009 KTM 450 exc. I live at 5500 feet. I have a keihin carb. I currently have it set up with
      green needle (jd kit) @ 4th from the top
      main #175
      pilot #42
       in setting it up for some desert riding I plan on doing next month (LAB2V). Right  now I’m getting a bog if I rack the throttle a few times. I’m reading this is semi normal as the accelerator pump has a hard time refilling.
      i have put a new diaphragm, spring, lean jet is at #40 and air fuel acre 1 and 1/8 out.
      im planning on going back to 172 main, red needle 5th from the top and #45 pilot.
      i normally ride the trails around lake arrowhead and Big bear in California. The trails are single track from 5000-10000 feet.
      Anyone see any issues with either set up?
      how about the big if I get on it a few time ( not really noticeable when riding)
      sorry for the questions. This is my first carb I’ve ever worked on.
      Thanks in advance
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
