non-invasive replace klr250 output seal?
As above... Is it possible to replace the output shaft oil seal on a klr250 without splitting the cases?
The manual recommends replacing the seal when replacing the main output bearing. Pressing both in at the same time. From the inside!
Hopefully that isn't the only way as i've just got the motor back together. don't really want to have to go through all that again.
