IMS 4.0 Installed But...
I did the install yesterday on my S and all went pretty well. The only issue I have is that the front of the seat keeps popping up off of the "tounge" on the tank. The tongue just doesn't fit far enough into the seat. Should I mod the tounge to move it back farther or what?
While I'm at it. I removed the vapor line coming from the upper part of the stock tank leading to the valve below and plugged it. Should I just scrap all of the vapor recovery stuff and plug the two carb holes which would remain?
Let me see. In short the IMS tank bites!:cry:
I have the same bike same tank same problem.
I made my own bracket and extented it by a 1/2 inch.
Works fine now. This is the second IMS tank I have had
problems with. Good luck
PS make sure the two tank mount at the back are right side up.
I guess I'll weld a little tab onto the tongue to extend it. As for the rear mount, I have the grommets higher than the frame. I think thats what the instructions called for...they were a little vague. The grommets look stressed out though.
Two words for ya Doc, Clarke 3.9.....:cry:
If you dont mind that wide beast between your knees.
I've got a 4.2 with a Moose seat, and it seems to fit just fine. I'll try and remember to check how it fits with the stock seat.
-f-
I installed an IMS on my bike. The first one was screwed up and Baja Designs send me a new one. The second one fit OK but not perfect. Not much problem with the seat, although I had to install a shim between the bracket and tank for the seat to fit.
As far as the grommets go, mine are installed just like on the old tank. That could be the problem with your seat. One more mod I had to do is install a couple of washers along with the spacer up front where it mounts to the radiator so it would clear the guards I have.
I have the bike all apart right now or I would shoot you some pictures.
One more thing when I installed my seat the first time I needed to use some silicone spray on the rubber pads so I could get it in place, after that it seems to go on OK. I will see what happens after it the seat is off for awhile
Good luck.:cry:
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
