i just got a 2005 kx 250f is there anything i should know about it
i just got a 2005 kx 250f is there anything i should know about it? i heard that there were some vavle issues and something about taking the bladder out of the fork seals could someone tell me anything
thanx
Check the valves after the first couple rides, mine went a little tight after the first 3 rides. Very easy to check and shim if needed. I just messed with the clickers a little for the suspension and it works great for me. Just go out and have fun, wish I could but the snow has taken over.
change the oil and filter very often, check the oil level before every ride. ride-smile-ride-smile...............
if you are not familiar with 4 strokes then ride it for an hour or 2 and take it to a dealership to have the valves checked. You should check the valve clearances about every 10-15 hours. That is VERY VERY important. Also changing the filter and oil regularly. i bought a stainless filter so i change mine every ride. Oil is what keeps the 4 strokes running good so if you have nasty oil, expect to blow something up.
