Wide Ratio Trans, Anyone try it?
anyone ever install one of these? was it difficult to install, did you like the end results?
I have had one in by 03 for about a year now. I like it. I installed it to get more top speed out of it. I am still running a 13/50 sprocket combo. I would not say the installation is difficult, but it is time consuming. You must pull the engine from the frame and split the cases. You also have to grind the case in three places for clearance. I would get a service manual. The manual is really good and is pretty clear. The cost of the trans is pretty high, especially when you consider the extra stuff you need. (Gasket kit, service manual, flywheel puller, etc.) I would do do it again, but I will admit I do sometimes think about the amount of money I spent on it.
Doug
