XR100 115 cc Takegawa Kit Help
I have a YZ/XR100 conversion bike that I have put a Takegawa 115cc Superhead kit on. So far,I haven't been real impressed with the power. It runs good, but not great. I read a lot of the posts here and you all seem to like the 115cc kit. A lot of my buddies have the Engine Only 120cc kit and they seem to run WAY better. I have put the 200x carb on, DMC pipe, stock airbox w/ lots of breather holes so it should be breathing OK. The motor is a 1981 with points ignition. I am not sure if the ignition could be holding it back or not nor can I find cam spec's for the kit to see if cam timing could be the issue. Does anyone know if the Kitaco or even a stock CDI ignition makes that big of a difference?
I can tell you that the beat 115 kitted motor I just bought, is much faster than a stock xr80 or xr100. I don't even have the superhead version or a rev box
Remember it aint gonna be faster than any 2 smoke even a 65 will stomp it on the pipe I bet. On the other hand the powerband is smooth and pull good from idle on up. I presume the superhead will give a better top end rush.
With 80 gearing the wheel pulls straight up in 3 and 4 gears.
The 80 motor only did it in 2nd.
You should have way more power. I would suggest new points at least, convert to CDI or a Kitaco Inner Rotor CDI kit. The Kitaco is the way to go and they rip. You need the "right" kit for the early XR100 points motor.
  • Similar Content
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
    • By Wayno50
      Nostalgically bought this bike because it’s same model/year/size of what I had as a kid in the early 90s. I should have looked closer but was blind to its issues. Kid before removed tailpipe and put on a silly silencer which I just threw in the trash. Thankfully he kept track of OEM tail pipe but cut the end off of it.. I can only guess to make it louder. I have pipe back on bike but back pressure not good and sound not as tight as it should be. Does this need packing? Can I get a retrofit tip for the jagged 3” end?
