Question about a possible timing mod
I was told by a friend on another board that there is a mod for the DRZ that tricks the timing computer into thinking you're always in 5th gear, thus giving you more power on the low end. Something about installing a resistor somewhere unspecified.
In searching this forum, I was unable to find any info on this mod. Is it real or was my friend blowing smoke?
Idid hear something similar relating to the Hayabusa though, maybe thats what he was thinking of. What are all your thoughts?
My buddy, despite the comments from this forum, is still insistant that there is a TRE mod for the DRZ. He said his brother did it to his '02 DRZ-400s and the low end was vastly improved.
There can't be. The DRZ doesn't have electronic fuel injection so can't vary the fuel mapping for different gears and revs. The only thing the CDi can do is vary the spark timing but, since it doesn't take any reference from the gear position indicator, it can only be advancing or retarding ignition according to engine revs.
Ian
Well then,,, by all means enlighten us..
But please,,, we need more then,, So and so said it worked...
Were damn sure,, it is not applicable to the DRZ,, based on what we know of the CDI, and the other wiring circuits involved.. So,, If you can,, find out what was done,, how,, for what reason.. And ask them to explain the reasoning for the mods.. as so far,,, what you have brought out on this does not make any sense..
Thanks for asking,, This should be interesting one way or the other..
.. I just had an vision,, This thread and others like it,, are like an on line version of “Myth Busters”
:cry:
:cry:
Just so you know, I am NOT doubting your expertise on the DRZ. I am merely relaying what I have been told.
From what has been said here already I am very inclined to agree that there isn't a TRE mod for my bike.
He did say he'd find out from his brother, so... hopefully I'll know something more before too long. Perhaps the guy did find something new.
simply inform him that the gear position sensor on the drz only makes the nuetral light function.
just becuase its a suzuki doesnt mean its a fuel injected suzuki.
:cry:
i was thinking more like crank yankers :cry:
I was looking at the wiring diagram and have two questions:
1. Any idea why the neutral switch has three wires? Two would be enough, surely?:
black/white=earth
pink=feed to the CDi
blue=feed to the neutral light
2. Is the white wire from the CDI to the coil a reliable source for a rev pulse?
Cheers
Ian
the pink wire is part of the safet switch circuit as well.its either open or closed to ground.
as far as the white wire goes,it depends on waht your looking to do.that where i clip the inductive lead for the dyno tach.
