xr250 kickstarter problem
I recently got some parts powdercoated, including the clutch cover and ignition cover. I put it all back together today, and put the kickstarter on, hmm went down but didnt come back up!? Is this because there is no oil in the engine or am I looking at a more serious problem? I dont hear any grinding or crunching noises. Any thoughts guys? Thanks
fixed
Here are some pics of my bike now after a winter of sitting around!
http://bikepics.com/pictures/292529/
http://bikepics.com/pictures/292530/
http://bikepics.com/pictures/292531/
http://bikepics.com/pictures/292532/
http://bikepics.com/pictures/292533/
http://bikepics.com/pictures/292534/
did ya hook up the return spring?
Ive got a spring lying around, i thought it was for the rear brake. Its for the kickstarter? hah i need to get a manual. Where does this spring hook to?
Mine either doesnt have that spring(never did), or its there and i didnt notice it. But i know if it is there, its not out of place, i would have seen it out of place when i put that washer on.
well bro i dont know what to tell you, every kick starter i have ever seen has one of those coil springs around the kick starter shaft. its possible that it is still wrapped around the shaft, but you didn't hook one end on the hole on the eninge case. the other side of the spring hooks into the shaft itself.
check out the photo again. look at the top left. you see one end of the spring hooks into the case itself, not the cover
I took the cover off, the spring is there, but behind the gear not in front of it. But i found the problem, but dont know the solution. I tighten the cover down, the kickstarter doesnt work, I loosen it, it works. What the hell is going on here?
Come on guys, I reallly need your help. Do you think this could be caused by not using a gasket? Maybe the gasket spaces it enough to where it wont bind up? I was using gasket sealer instead. Does TT have gaskets?
Do it right.
Go buy the XR2.5 Honda Service manual and the Honda gasket from your dealer.
There is a difference in the design of the XR2.5 vs. the XR4.
The assembly proceedure is specific to the bike.
Well, i WAS doing it right the entire time, well sort of. I got the gasket in today which i ordered from service honda for $12, the local shop wanted $23, my ass. I put the gasket on, tightened up the cover, violla! the kickstarter works, so i guess the cover is meant to be gapped the width of the gasket in order for everything to work properly.
On smokin's bike, when you kick it the kickstarter doesnt come back up. But the reason why is that we have to have it all the way in so it doesnt slide off cause the bolt on it is stripped and the threads on the kickstarter is worn. :) He wouldnt just get a new one. :)
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
