Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
My xr100 has a lot of thrust play in the crank
It's really noticable. The xr80 motor I took out had no noticable play.
It seems not to have any up and down play just side to side.
Makes a notibable "clunk". Either the bearings are toast or they are spun in the cases. Turns very smooth though. Any recommendations? Can I pull the crank and have the bearings replaced or does it come as a unit?
Maybe I should send it out and have the whole motor stroked? 135 maybe? Can they do it with the takagawa piston? Do they use s short rod or a short piston in the stroker kits?
Thanks
Honda will sell it in pieces or the entire assembly (from lower chain gear to oil seal) but get the assembly it is a lot cheaper. Check various years I found the 97 to be the cheapest with Service Honda.
Well, I called powroll last night and they told me that the xr100 has a lot of side to side play between the crank and the cases! I told her it was like 1/10" and she said that is normal!! She said, yup and the output shaft has the same play in and out. Is this right? It doen't appear to be rubbing anything it just "clunks" in and out. My 80 engine has no play in or out. She says it is different on the 80. Hard to believe. Can I believe it?
I'm ordering a camchain but I am having a heck of a time getting the pulse generator bolt out of the ignition. I hope the last guy didn't use red loctite or something like that. I'm afraid to heat it becasue of the possiblity of melting the pule generator nearby. Any tips here?
Lastly I think I found the source of all that noise. When I loosened the lower camchain adjuster bolt I noticed the lock not was tight but the screw itself was not bottomed out! The tensioner must have been bouncing all over the place in there. The good news is the lower sprocket looks good as far as I can tell by shinning a flaslight down on it from the top of the head.
Thanks Socal. I've ordered the camchain and stuff from Ron Ayers. Gonna take a week to get it. I'll try to set the tensioner manually in the meantime so I can take it for a ride.
  • Similar Content
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
    • By Wayno50
      Nostalgically bought this bike because it’s same model/year/size of what I had as a kid in the early 90s. I should have looked closer but was blind to its issues. Kid before removed tailpipe and put on a silly silencer which I just threw in the trash. Thankfully he kept track of OEM tail pipe but cut the end off of it.. I can only guess to make it louder. I have pipe back on bike but back pressure not good and sound not as tight as it should be. Does this need packing? Can I get a retrofit tip for the jagged 3” end?
