CR 80 carb fit TTR 125?????!!!???
:cry: hey, I am wondering if anybody knows if the CR 80 carburetor will fit the ttr 125. I know the YZ 80 and KX80 will, but i need to know if the CR 80 does. Thanks a lot everyone.:cry:
A "Yes" it does fit into the manifold and a "No" it wont fit into the airbox boot. You would have to use a pod aircleaner and rejet if you wanted to use it. I'm not sure about the KX carb but from memory depending on the year its same as the CR80 carb (up to the 05 which now has a PWK flat side finally) or on very early ones is a early flat slide.
