Rich or lean?
If you had to choose, would you run rich or lean? Why? I'm going on a ride in a couple of weeks that's starting out at 3000 ft and will finish up around 7500 ft. I figure it's better to be lean down low and right up top, but what do ya'll think?
You are going to want to shoot for correct jetting for 4000 feet. You will be slightly lean at 3000 and a bit rich at 7,500. If you jet for 7,500, you may be too lean at 3000. It is always a compromise. Jetting is rarly perfect becaue air density changes with altitude, temperature and barametric pressure.
