Bent Subframe
Well I've straightend alot of them with just a blow of a BFH (big fricken hammer), take the seat, side numberplates, muffler and rear fender off, take a few wacks and then set the rear fender back in place to see if it lines up with the rear wheel, keep hammering away till she's straight, that's my best advise without shelling 200 on a new one.
If you get a long enough pipe over the end you can slowly move it back into position. Leave it on the bike and have someone hold the bike from moving as you leverage on the pipe. The trick is getting a strong enough pipe over the end with enough length to give you the force needed to bend the subframe back, and it takes conciderable force.
Merlinn
How did u manage to bend a sub frame it would be wise just to buy a new one because even if u bend it back it still wouldnt be straight and it would throw your bike off center so you should really just buy a new one and this way the subframe wont be weakend by anything
