oil leak
the other day i went to go check my valves for the first time and went to go remove the plastic plugs to get it t.d.c. and opened the large one to do it with socket and oil started pi$$ing out.
is this normal:confused:
closed it back up drained the lot ,then checked clearences.......sweet as.
put fresh oil in and droped about 1.3L in ,manual only says 1.2 inc.filter and i didn't replace mine
any ideas and can i repair it myself:excuseme:
all the oil will drain into the crankcase within a day or so. You're not the first to learn this the messy way. I usually run 1.5 liters, it will hold around 1.8 without any concerns.
thanks man i was stressing out for a while there
my mate got his clearances checked at his local and told them what had happened to mine and they said that was f@$ked and something was wrong
